Bob's RV-8 Build Site
Date:  1-23-2018
Brief Description:  Fuel Pump/Filter and clean shop
I started getting to the business of attaching the fuel lines to the pump/filter with the brackets
attached in order to locate the position that I want to secure the brackets. Anyway, when I went to get the fittings to fabricate and install the last fuel line to firewall and found out that I did not have the right fittings to do the job.
The fittings that came with my kit which was from 2006 had different fittings due to the different fuel pump setup that was mostly used at that time. The fittings provided had one end with pipe thread and the other with compression fitting. I need fittings with compression on both ends since I am using the Airflow Performance pump. So I have to order the right fittings.
I decided the shop needed a good cleaning...so spent most of the time in shop cleanup.
Connecting line to fit bracket on filter
Connecting fuel pump line to locate pump bracket
Oops....these wont work!
