Bob's RV-8 Build Site
Date:  1-1-2018
Number of Hours:  3.50
Brief Description:  Fuel Selector Install
I completed the fuel selector bracket today. I drilled the location for the selector. The instructions state that the max thickness of the bracket can be 1/8 inch. This is mainly for the bezel that fits around the center part of the fuel valve does not rub against the fuel handle. It seemed to be flush but I wanted to have a little clearance so I milled a pocket on the back side of the bracket in order to have the valve sit up a little more and allow a little more clearance.
Next I drilled and countersunk the holes for the rivets to attach the bracket to the airframe. I clecoed the bracket to the airframe and checked everything out. I drilled the three holes for attaching the fuel valve and bezel to the bracket. Everything clecoed in very nicely.
I riveted the nutplates to the selector and all is complete for the time being. I will not rivet the bracket to the airframe until I paint the interior and finish all the fuel lines. I think it came out good and will have room for storage compartments around the selector.
WELCOME 2018.....good start to the New Year!
Selector
Selector
Selector
Selector
Backside view with pocket milled
