In this session I drilled the #10 hole through the the F-818 cap and F-817 slide to attach them together.
Next I located and drilled the F-874 nylon end caps in their proper location. I bolted the end caps in place. The plans call for being sure that the rudder weldments do not bind. Check and good!
