Bob's RV-8 Build Site
Date:  8-23-2017
Number of Hours:  1.50
Brief Description:  Battery mount (cont)
Tonight I machined the rear mount angle to fit the milled out portion of the tubing. This will hold down the rear portion of the mounting tube and will bolt to two of the bolts used in the right gear tower. I also machined off some of the angle to clear the rivet heads on the bottom of the gear
tower angle. So far so good.....
Machined to fit tube cutout
Hole location marked for angle
