Spent some time fitting the brass bushings on the control column. Kind of a tedious task getting the angle of the control column and with marking and using the belt sander I was able to get them in the ball park...but they need more work. I also ground down the pivot bushings on the front and back control sticks to get minimum spacing between control column and the control sticks.
Things are roughed in now and will do some more work on the bushings on the next session.
