Brief Description: Flap blocks and control arm bracket
Installed the floors back into the interior. Trimmed flap blocks as per print instructions. Positioned flap weldment and blocks into position. Drilled holes for flap blocks. Installed F837-1 control arm bracket to match drill rear holes.
My kit came with the parts to manufacture the F837 bracked. To manufacture the F837 bracket it used two short pieces of 3/4 square alum tubing and a piece of alum angle that had to be cut and contoured. I saw the F837-1 bracket in someone elses build log and called Vans to get pricing. It was very reasonable so I ordered one. I felt it was a lot better setup than the old F837 bracket.
