Bob's RV-8 Build Site
Date:  10-18-2013
Number of Hours:  1.70
Brief Description:  Aileron Bellcrank initial alignment
Tonight I used the aileron alignment tool in order to set the rod ends at the right length. I split the dfference so each rod end is threaded into the control rod very close to the same depth. Not a hard process and really the most difficult process is getting spacers and washers on the aileron hinges.
Had some help from my favorite assistant and partner.....she even came dressed with Lycoming shirt and VAF hat.....she is a great helper and wonderful project supporter!
Aileron alignment to gage
Bellcrank rod set...note jig W730 below
My best and favorite helper...note Lycoming Shirt & VAF hat
