Removed elevators. Inserted washers on each side of bearing block which required mixing and matching washers because the distance between each elevator is different. One of mine was .135 and the other was about .184. Wasn't easy to measure....but the calipers got me pretty close. Then I used feeler gages to nail down the thickness of the spacer.
Once again....I am going to make a couple of stainless steel single spacers to instead of using the stack of washers.
