So I completed the first part of the practice kit. Learned how to match drill holes properly by messing up one hole. Learned how to drill out a rivet because I put two of the wrong rivets in the wrong place. Learned that you need to double check the depth of micro stop countersink or you will mess up the part. All in all the pracitce part worked out good and it did what it was suppose to.....learn things without messing up the real airplane!!!
