Bob's RV-8 Build Site
Date:  10-24-2021
Number of Hours:  4.90
Brief Description:  Wing tips continued
I continued on the wingtips today in order to try to get them closer to being completed.
I began by riveting all the hinges to the left and right wings. Out of 144 rivets installed I only had one goof up and had to drill that one out and install a new one.
I moved on to the wingtips and countersank all the holes in the tips. I left the hinges in the wing tips while countersinking them as it added rigidity to the process. I countersank them just a hair below the surfact in order to cover them with micro.
Next I removed the hinges and deburred all of them. The wing tips are ready for riveting the hinges. I will use some proseal adhesive also between the hinges and the fiberglass tip to assist in getting a good bond due to the possibility of the rivets wanting to pull through the fiberglass. It is not that probable that they will but just some extra assurance.
Hinges riveted to wing
Wing tips countersunk
