Brief Description: Pmag Ground Wire & Remove Smoke Tank
Got out to the shop tonight and completed routing the 18AWG ground wire for the Pmag harness from the firewall through the inside of the airplane. Laying in the cockpit is not comfortable especially while routing and lacing the wire as you go......but it's done!
I decided to remove the smoke tank and baggage floor for better access with running wires. I just have to figure out how I want to connect the smoke tank power for when it is in the airplane on a temporary basis.
