Bob's RV-8 Build Site
Date:  5-27-2022
Number of Hours:  1.50
Brief Description:  Right Console Warning Lights
On tonights short session I was figuring out the grounds for the three warning lights that I have on the right console. I have the starter engaged light, and the main & standby alrernator fail lights.
I want to be able to remove the panel and the lights without cutting wires. So I finally decided to use knife splices and put the three grounds on one fast-on tab to the grounding block. The lights draw so little power it is the most optimizing way to do it.
So I made up the triple wire bundle and placed it on the forest of tabs in the avionics area.
Right Console Warning Light Grounds
