Bob's RV-8 Build Site
Date:  4-21-2022
Number of Hours:  1.80
Brief Description:  Misc Electrical Work
I continued with dressing the ground wires in the electrical bay with lacing.
I then worked on the right console angled panel and laced the warning light wires together.
I realized that the bracket I made for the PIC control stick wiring AMP connector needed to be modified to get the connector wiring on and off of the bracket in order to get the seat ramp panel on or off without taking the screws off of the ramp. I mean it would have worked ok doing it that way but if I ever needed to get the bracket off for any reason it would be cutting a notch with the wires going through the hole and that is riskier than I want to tackle.
I gathered the cables and hardware to re-install the parking brake and ALT Air brackets but stopped short of getting them installed tonight.
Warning Light wires
Warning Light wires
Modify AMP Connector Bracket
