I finished off the ignition buss wires tonight. I put the console panel on for a little and got the length where I needed to cut the wires to length and add the ring terminals and labels to complete the buss. I used spiral wrap and lacing for a little more wire protection.
Next I routed the indicator light grounds from the Dsub. I put an adel clamp on the transponder mount to capture the wires and I will double them back in order to have service loop for the wires since they solder to the LED lights. I will not hook them up until I get the "real panel" in place as I have the prototype panel in place currently and the light wires would have to be cut to get the lights back out....which is counterproductive. I put labels on the wires to identify the grounds.
