Brief Description: Right Console Panel & Dsub bracket
I continued on building the remaining switch and LED lights into the right console panel. It is now complete and ready for wiring.
I turned my attention to the bracket I am going to use to hold the Dsub that will be used for the grounds for the switch indicator lights. Since I have a bracket that I am no longer using for a wire bundle, I am going to use it to attach a 9 pin Dsub to corral the grounds and only have a single ground go to the ground block. I have 8 indicator lights on the instrument panel and three on the right console. I am just going to use the Dsub on the instrument panel lights.
So I sketched out a Dsub connector bracket that I need to cut out for holding the Dsub.
