Bob's RV-8 Build Site
Date:  3-18-2021
Number of Hours:  1.60
Brief Description:  Firewall Pass-thru 2 & Voltage Regulators
I worked on deburring the second firewall pass-thru. Most projects use two as you don't want to cram each pass-thru full of wires, you want to have room to add a couple if need be or remove them without yanking on all the others in the bundle. This one will go on the left side of the firewall. All I have to do is radius the four corners and it will be done.
Next I got out my upgraded voltage regulators and mounted them on the bracket that will go back into the airplane. They were upgraded free of charge from the great folks at B&C Specialty Products. The upgrade from LR3C to LR3D will allow less false trips and using LED warning lights. It was worth it and I had them ship a couple items back in the box...so it was a win-win.
I attached the ground wire harness that I made prior to taking them apart to ship to B&C.
Second Pass-thru
Second Pass-thru
Ready for re-install
