As I was getting the components in the electrical bay, I was looking at wire routing. I felt that wire routing needed to also be done on the outside of the electrical compartment. I plan to run the positive wires along the outside of the electrical bay and run the ground wires along the inside panel with the wire tie down panel.
After considering routing I planned on making a small wire tie point and attach it to the outboard battery tray. I got a piece of 1/16 aluminum angle and began to work up the design. I cut one long edge to get it the same width as the attachment angle. I measured the locations for the two screws and ended for the night.
