Brief Description: Modify battery tray and tie down panel
Part of the building process is making changes. Such is the case with the addition of the wire tie down panel.
I made the panel and everything looked fine. While looking to put in the battery tray in this session, I realized getting the bolts in the tray through the back side of the wire tie down panel.....though potentially doable.....would be more time and challenge than I cared to tackle.
I decided to do a fairly easy fix. I removed the nutplates that were in the battery tray and transferred the holes into the wire tie down so the bolts will go in from the battery side of the tray as opposed to being put through the back side of the wire tie down panel and into the battery tray.
The panel and tray are ready so next session I will place them into the electrical bay and make sure everything lines up.
