Bob's RV-8 Build Site
Date:  2-11-2023
Number of Hours:  3.00
Brief Description:  Work Snorkle Insert & Bond Cowl Ducts
With the inset I molded being fully cured, I set about to strip it from the mold. Overall is fit good but I had to start trimming it in order to get the plug to fit in place. After quite a bit of fussing and fitting it was ready to be bonded into the snorkle. I mixed a small batch of flox and bonded the insert in place used some fiberglass pieces to lay over the flox. I used a brush to work the fglass in place and then set the snorkle aside to cure.
Later that night I went into the shop and removed the upper cowl that Rob and I completed earlier that day and bonded the cowl inlet ducts into the cowl using Cab-o-sil that I bought on Rick's recommendation. The process was pretty simple and did not take real long. After getting all the surfaces bonded and cleaned up nice I placed them back on the aircraft to get them to cure in place during the night.
Another good day of progress.
Broke 3500 work hours on the project.....almost embarrassing.....
Molded snorkle insert bonded in snorkle
Cowl Ducts Bonded
Cowl Ducts Bonded
Used Cab-o-sil to bond ramps
