I continued working on the baffle brackets for the baffle seals. I put the photos in here but tonight I was still working on the baffle seal brackets. I finally finished off by getting the brackets for the front baffles completed.
The front seal baffle brackets are just made out of sheet aluminum. I made a pattern for each one using poster board and then cut out the aluminum to match the pattern. That seemed to work out decent.
By the end of the night I still had more brackets to make but I should finish tomorrow.
