A session of really working the baffles for fit. There are a lot of points to look at and when looking over the parts you see something here or there needs adjustment so off come the parts. After getting the parts back on it's back on the engine to see the fit and then possibly removing again for more adjustment.
I am trying to make small asjustments in order not to make big blunders. I found the rear intersection of the 3 & 4 baffles needed clearance by the engine so I had to remove to work them and make some other adjustments.
