The shop is getting cluttered with the machinery and the project. I decided to whip out some shelves with some 1x10's in order to get a little more order with the multiple hardware cases to get them out of the way. and clear up bench space.
I got the fittings in from AN Plumbing for the red cube. I had to make up a little -4 hose with fitting in order to hold the red cube vertically while I was trying to fit and get the bottom hose dimension determined. Didn't quite get that completed before the session ended.......will pick it up next time.
