Bob's RV-8 Build Site
Date:  7-4-2022
Number of Hours:  1.30
Brief Description:  FT-60 Red Cube
Lots of work around the house to get done today...so just a short session tonight.
I temporarily placed the fuel servo back in place because I have to get the placement for the fuel flow transmitter affectionately known as the "RED CUBE". It is an item that is made by Electronics International and is very accurate when set up and working correctly. You can get real accurate information on exactly how many gallons per hour of fuel you are using and how much fuel you have remaining in the tanks as well as time left. These little beauties provide a lot of helpful information!
Anyway I have to get hoses made and I am trying to see exactly where I want to place the cube that it will be in a safe and secure place and then make hoses. Last night I determined I may have to do a little work on the starter cable to get more room and clearance.....so will work on that next session.
Fuel Servo in again
Fuel Servo in again
Working on Red Cube Placement
