I final drilled the clearance holes in the baggage wall to attach the AOA brain box. I inserted the o-rings as isolators....I think I will use them in the final assembly
Notice the cap I drilled and inserted into the AOA cover. The two white marks that I put on there with a paint marker designate where a small screwdriver can be inserted to press in the tabs and pry the cap off in order to adjust the internal volume potentiometer.
I decided to prepare to assemble the Guy or Gal in Back(GIB) reading light. So I took some time to get the bag of parts out and review the schematics and assembly instructions. Will begin the actuall install next session
