I started the session by cutting the largest opening on the right side which was the GDU 450 hole. After that the right side was complete.
Next I set up for the GMC 507 in order to cut that smaller opening first. That was completed also. Next will be the Flight Data Chrono followed by the GDU 460 display and then the switch and light locations. I should have 8-10 hours in writing programs and machining the panel....the real one will go faster because the programs are written. Unless I have to make a lot of changes.....
