Brief Description: Skirt fitting continued - Annual Hours Breakdown
For all the hours I put in today I have little to show for it. I worked the right skirt quite a while and got several iterations getting it still closer....but not satisfactory. I will have to cut and do some fiberglass work which came out of my conversation with Rick and Jim.
I decided I should get some of the cuts marked and ready for further trimming. I marked the top of the skirts for cutting. Then I laid a line on the back of the canopy for cutting the excess there. I figure if I need to get it a little closer to finish. Good thing about fiberglass is that it is very stable and really doesn't change a lot with cutting.
So far I started this project around September 2012. Total hours thru 2019 =1331. Here are the yearly stats:
