Bob's RV-8 Build Site
Date:  12-27-2019
Number of Hours:  3.00
Brief Description:  Drill canopy roller bolts
I removed the skirts from the airplane in order to drill the holes for the canopy rollers. Drilled rollers for left side and right side. I realized that the frame was rising up occasionally as I was manipulating the skirts...had a "duh" moment and figured I better put the bolts in to secure the frame.
Re-taped the canopy skirts on and began to play around with more fitting. This is a real challenge.
Left roller bolt drilled
