Brief Description: Cutting and Fitting the Canopy Part 11
Tonight I only had a few hours to work in the shop. I put the canopy in place and found I had to trim the bow to even it up a bit. So the blurry blue line is the cut line that will need to be cut.
Once again.....after the flange is cut off the canopy and you make successive cuts...the canopy moves around a bit so sometimes you need to retrim here and there. I will cut it tomorrow night.
