Bob's RV-8 Build Site
Date:  9-10-2018
Number of Hours:  2.20
Brief Description:  Left Elevator - Rework
The trim tab spar is riveted in conjunction with the top of the elevator skin and the hinge for the trim tab. When I removed the trim tab spar to change the elevator skin I ended up with several holes enlarged in the hinge portion. They were still usable I guess....but I just didn't like it so I decided to make a new half of the hinge again. Another fact was that the original had about a .250 gap between the trim tab and the elevator trim tab skin where the tabs were bent. The plans call for a minimum clearance of .093, so I just didn't like that large a gap.
The hinge that is used is an MS20257-2 hinge which means the flange part of the hinge is about 3/8 of an inch. I didn't have any more of that hinge available, but I had bought some MS20257-3 that I bought for making the hinge on the avionics access door which has a hinge flange of about 1/2 inch. So rather than order -2 hinge I just trimmed about 1/8 inch from the -3 hinge and made a new hinge to re-install the trim tab. The process of measuring, cutting and finishing the hinge took a little longer than planned but finally was done.
Next I fitted the hinge to the trim tab spar, checked and double checked it with several fittings and finally match drilled it and riveted the hinge, skin and spar together. I put the trim tab on one more time and measured the gap at just about .100....just right!
Couple holes compromised
New Hinge in place
New Hinge in place
"Jimbo" fitted and ready to go
