Bob's RV-8 Build Site
Date:  1-8-2023
Number of Hours:  3.90
Brief Description:  Cowl Inlets and Baffle Trimming
I continued on with getting the cowl inlet ducts placed on the top cowl. I was surprised how good the ducts actually fit the contour of the cowling and fit into place. I drilled and clecoed the back edges of the ducts in place on the cowl.
Next I placed the top cowl on the airplane in order to see where I had to trim the baffles in order to get the cowl to fit with having the inlet ducts on now. After getting everything squared away I measured about a 2.25 inch interference from the inlet ducts. I used Robs method of putting a marker through a stick (the same one I used to trim the baffles origonally) but instead of using the 4" marker hole I drilled another one at 2.25 inches. There was room to get the stick in without having to cut it so I marked all the baffle areas that had to be contoured around the inlet ducts.
With that done I went through the process of cutting...rechecking....cutting more.....rechecking again, rinse and repeat steps until I finally got all the baffles contoured with the right gap for the baffle seal to be installed.
I put the top cowling on the last time and double checked everything......appears to be all systems go!
Stick Profile Marker
Side and center baffles cut for Cowl Inlet Ducts
Almost done....fitting it all together!
