Bob's RV-8 Build Site
Date:  12-21-2022
Number of Hours:  1.40
Brief Description:  Baffles
I continued the brackets for the filter. I had to drill and trim the inboard bracket. I then took both brackets and marked the bend line on them for the small bend on the filter side of the bracket. I used my small pieces of wood to get the angles bent in the brackets....the bends may need to be adjusted a bit after the snorkle is installed.
I then began to work the 702E Left Ramp Support Plate. I had to sneak up to the place where the screw would align with the hole by making several cuts on the plate to get it in position. Next step will be to get the support angle located and drilled to the plate.
Inboard Filter Bracket finished and both bent
Working on left ramp support
