I worked on the ramp for the left side inlet where the snorkle will go. I did some drawing with markers after having taken multiple measurements and I feel pretty confident that I have good parameters.
I also had to set up the angle that will attach to the rear of the snorkle and put a slight bend in it where it will be connected under the main bracket that goes in front of the cylinder.
