Bob's RV-8 Build Site
Date:  10-10-2022
Number of Hours:  4.30
Brief Description:  Baggage Door and Blocks
I started by trimming the cowl since I could take it outside into the beautiful weather and do the trimming.
With that completed I went back to working the baggage door. I found that the locking pins extended enough to push on the rear bulkhead and the front firewall just slightly. I ended up trimming the pins on both sides in order to get them not to touch. I took about 1/16 " off each pin.
Then I worked on filing the sides of the baggage door. There wasn't enough clearance for paint so I draw filed both sides to get the clearance needed.
Finally I worked on the blocks. The Vans instructions called for drilling a hole through the firewall and rear bulkhead and using pins to align the blocks. I REALLY didn't like that idea! I once again called Rick and talked it through with him and worked out a process that will NOT involve a hole in the firewall or bulkhead. The blocks were a bit mommicked at the ends so I threw them in the mill to square them up. The blocks are also too thick and will have to mill them thinner also.....next session!
Trimmed and sanded
Trimmed and sanded
Working the pins
Working the pins
Working the blocks
Working the blocks
