Bob's RV-8 Build Site
Date:  8-31-2022
Number of Hours:  2.10
Brief Description:  Install Red Cube Bracket, Fittings, & Safety Wire
With the paint dry on the Red Cube bracket I decided to install it and get the bolts torqued.
After that I put the thread sealer on the fittings that go onto the Red Cube and installed them. So the cube is ready to be installed but I will wait a little for that...I have to get one more hose made that goes from the upper straight fitting on the cube to the flow divider on the top of the engine and will need to install it to get that measurement.
Finally I decided to safety wire two sets of bolts that go through the firewall and hold items for the structure in the electrical bay.
Red Cube Bracket Installed & Torqued
Red Cube Fittings Installed
Safety Wire Bolts
Safety Wire Bolts
