Brief Description: Dimmer Control Spacers & Starter Cable v2.0
Last night I punched out some 1/4 inch spacers to set between the dimmer unit and the mount. The connectors between the GMA 245 and the dimmer were interferring with each other so tonight I epoxied the spacers to the mount and used the screws to keep them aligned.....after allowing them to dry for quite a while I installed the dimmer unit.
I decided to run the starter cable. I decided to move the routing to the left side of the engine due to the teflon hose that Superior uses to route the connection from the governer to the prop flange for the constant speed prop along the right side of the engine. I just felt there was too much there and it would just be better to route it over to the left side and declutter the right a little. Completed routing the cable and installing the two ends and several standoffs.
