Brief Description: Measure Throttle Body/ Servo Hose & Organize
I have been working with Tom at TS Flightlines to lock down my hoses. We have two left, the hose from the fuel servo to the input on the red cube and the hose from the output of the red cube to the flow divider. After speaking with Tom and going through a couple iterations of lines it appears that the best choice will be to put a 90 degree elbow in the bottom of the cube and make a 180 degree bend back to the fuel servo. I used poly hose to measure the curve of the hose for bend radius sake and it came out to about 7 1/4 inches. I will get the upper hose from the red cube to the flow divider made after I am satisfied the bottom hose is as needed and in position in order to get a good measurement for the top hose.
I placed the order with Tom at TS Flightlines so that is another step further down the completion road!
I then took some time to organize the modified work bench with the shelves to get some junk out of the way of trying to work! That cleared up a bench to work on!!!
