Too many things going on. I was in the shop only a brief amount of time because there is a big event at the airport that I volunteered for that I had to gather things to bring.
I went into the shop to "get something done" and continued by getting the 18AWG ground wire that will replace the 20AWG wire I had to remove from the harness. I started from the outside on the firewall side and started feeding the wire back into the harness. It was too hard to try to use the wire spoon and feed the wire through the original lacing so I just cut the lacing and re-laced the wire as I went.
By the end of the short session I had gotten the wire laced and fed through the two adel clamps and passed the firewall area into the inside of the airplane.
