Bob's RV-8 Build Site
Date:  5-8-2022
Number of Hours:  4.10
Brief Description:  Smoke Tank Install (cont)
With all the parts completed for the rear tank hold down I did some final fitting. Since the nutplates were drilled via scale and punch there were slight variations in the distancing which is why I slotted the hold down holes. They all went on great without pulling and trying to buckle the panel.
I then worked on the front holes by the baggage door area which were a little more of a challenge. I wish I had transfer screws for 10-32 threads but don't. So I checked out that I had a transfer punch that fit very well. I set the tank in place and got everything located then clamped the panel to the tank hold down angle. I drilled two holes and the removed the clamps and drilled the clearance holes in the tank hold down angle. I put the screws into the two holes and went through the process of drilling all the holes. I opened the holes up to the max I felt I should in order to keep any binding of the screws against the panel to keep it all straight. I got everything deburred and clearanced and tried the tank and panel in place.....result is great!! Now to run the lines and manifold stuff.......
Well I have broken the 3000 hour landmark. I look at that number and wonder how everyone tracks and logs their time. I put the time down on the log sheet and will sign in and out for breaks or when ending sessions. I really wanted to get an idea of how long it took me to finish this project so I don't want to skew the numbers either way. Well for what it is that is what I have recorded thus far. The hours are not the issue.....getting the project done is!!!
Bracket installed and flange slipped in
Rear of tank (left side of fuselage)
Flange on baggage door side drilled and secured
