Bob's RV-8 Build Site
Date:  4-25-2022
Number of Hours:  2.10
Brief Description:  Advanced AOA Plumbing
I decided I better get the AOA lines run as I need to get everything out of the airplane for the wings. The AOA lines and one more line for the pitot tube should be all I have to run to complete the runs heading to the wings.
I had a couple of blue and green tubing lengths from the kit but they weren't long enough to reach the cubby area in the right side of the PIC location. I actually bought some 1/8 tubing push in unions as I plan to place those in the cubby area with the wiring and make that the connecting point for the tubes that will go into the wing.
The tubing was coiled up into the wing in the shop when we attached it to the ports prior to putting on the lower wing skin with my friend Rick. I measured the length I needed from the AOA Module to the cubby and went to the other shop and measured the tubing coil to be certain that the length I cut off for the inside run wouldn't short me for the run from the wing to the cubby. Turns out I had plenty so I cut off the tubing I needed.
Went back into the basement workshop and began running the tubes toward the right side and lacing them and installing tie downs for zip ties. Got the tubes to the gear tower before quitting for the night.
AOA Module
AOA Module
Across the front towards the right gear tower
