Bob's RV-8 Build Site
Date:  3-19-2022
Number of Hours:  4.50
Brief Description:  Panel Switch Wiring
Lots of sitting in the PIC seat getting wires for the switches neatened up a bit in the routing and then cutting to length, installing fast-ons and connecting wires for indicator lights during the process.
Mostly just a bunch of detail work getting done, making sure the wires are correct, routing them so I have some service wire in the event of needing to redo some terminals in the future.
I also decided to re-mark up the wires for the Aeroled wing tip lights. As I stated in an earlier log, I decided to use all sheilded wire for my lighting. I changed the labels because I changed which wires I am using for which light. The Aeroled connectors are solid color wires....while the sheilded wires are striped or white.I decided to use the green striped wire on the ground, the blue striped wire for the taxi light, the orange striped wire for the landing light, and the white wire for the wig-wag wiring. Keeping it all straight is all a part of using two different kinds of wire for the same circuit.
I annottated the colors on the wiring diagram for the Aeroleds.
In the seat wiring switches
Most of the main switches complete
Getting the wires right!
