Bob's RV-8 Build Site
Date:  3-8-2022
Number of Hours:  1.70
Brief Description:  Sort & Tie Wires in Fuse-Relay Bay
I spent time using zip ties and lacing cord to get the wires dressed for the fuse-relay bay. If you compare earlier posts you will see that all has been cleaned up quite a bit. I am ready to secure the panel but I really need to get the Spar Cap covers riveted in place. The Vans instructions once again are a little obscure as to the sequence of when to install the spar caps. They are installed using blind pop rivets so it appears that you put them on when you think it is ok because when you match drill them the instructions simply tell you to not install them as they will be installed later in the process.....it just never tells you when????? Oh well....some common sense to be used here.....
I am using a number of indicator lights for my various switches and such. They have a white dot on the terminal for the positive (+) side....but some of them are a bit faded.....so I am going to grab my paint marker and redo them for good measure.
Wires dressed up
Wires dressed up
Indicator lights need white mark
