Bob's RV-8 Build Site
Date:  3-7-2022
Number of Hours:  1.80
Brief Description:  Fuse Block Matrix & Starter Engaged Light
Got a little work done tonight.....mostly administrative. I made up the finalized matrix for the Fuse Block. I was thinking of getting a rub on label for attaching it to the panel next to the fuse block but I decided against the idea because there may be changes in the future to fuse block and wiring and that would make the matrix obsolete. Instead I will put a page in the aircraft checklist for referencing as well as any other notes concerning the fuse block. I did make up a label to put on the fuse-relay panel saying to reference the checklist for fuse information.
I then decided to run the last two wires for the "Starter Engaged" light that I have on my right console panel. I will be using an inline fuse for protecting the wire since it comes directly off the big lug or the "I" post of the starter solinoid.
Fuse Block Matrix
Fuse Block Matrix
Starter Engaged Light Circuit
