As I came to the slots for the Buss Sense and Low Voltage lights on the regulators I decided to get those run as they haven't been run yet. It technically requires six wire runs. Two runs from the regulators to the fuse block for the Buss Sense circuits, Two runs from the fuse block to the warning lights, and two runs from the lights to the regulators.
I cut the wires and routed them to their respective places. The install instructions state that the warning lights can be attached to another existing circuit breaker or fuse from 1-5 amps.....so I decided to just attach it to the fuse block with the Buss Sense fuses.
I got most of it complete. I want to be able to remove the right console panel and/or lights that I have on it without cutting wires so I may use knife connectors on these lights in order to have the option.
