I basically did the same with the Nav/Strobe wires tonight from stripping the casings to getting the wires to where they need to be and attaching ground wires to the sheilds. In this case I am using the sheilds to to act as the ground for the Nav/Strobes. I once again used solder sleeves and ground wire to attach them to the ground block.
After completing that process again I began to sort and prep the CB panel to work on next session.
