Bob's RV-8 Build Site
Date:  2-10-2022
Number of Hours:  1.20
Brief Description:  Panel Indicator Light Ground Wires
Lots going on last night so it was a shorter session in the shop. I received my order of Dsub male and female pins so I could get the other half of the Dsub grounding connector made. I had a little scrap I could use but then had to cut lengths of wire for the remaining lights.
After cutting the wires I pinned them with the Dsub pins. I routed the wires to the empty indicator light holes. Next will be routing the wires and soldering the connections for the wires and placing labels on the wires.
Dsub ground wires to lights
Wires routed to respective lights
