Bob's RV-8 Build Site
Date:  2-5-2022
Number of Hours:  7.80
Brief Description:  CB Panel and Instrument Panel
Put a good work day in the shop today. I continued by putting the buss bar and installing the CB's into the panel. The black plastic washers work great as a panel protector and they torque great and give the breakers a nice finished look.
I installed the prototype panel that I machined out of 5053 aluminum sheet in order to use it for wiring the switches in location....that way it limits the possibility of damaging the completed panel or labels I have attached.
I ran a bunch more power and ground wires for various items. I am trying to get all the wires installed and routed so I can dress and lace them in place in order to get the final length from the CB or Fuse panels to the switches.
I had a sudden realization that I never identified or ran a Buss power to the Ignition CB's that reside on the right console panel. Not a big problem but a duhhhhhh moment! I decided to pull what will be a short (about 12 inch) wire from the top buss A lug on the Fuse Box. It is a very short run and I am using a size 14 AWG for a 6 amp total draw.....plenty beefy. I am placing vinyl wrap and protecting the wire from shorting in every way due to the nature of Buss Feed wires being unprotected by circuit protection devices.
Buss Bars and CB's installed
Using Prototype panel for wiring
Ignitions on Right Console
