There are two thoughts on pre-wiring wings and fuselage prior to the "great assembly" of the two. Some folks stage all the wires in the wings and feed them into the fuselage and others stage the wires in the fuselage and feed them into the wings. I have decided the latter is the way I see fit to do them as I believe it will be easier to do the end point connections in the wings than try to route wires into the instrument panel area and make connections at that late a stage in the build process.
So I looked at routing and got the wires together to that I would be using for the feeds to the Wing landing lights, the Nav/Strobe lights, and the Aeroled Wingtip landing/taxi lights. I determined my routing and just started running a couple wires.....but I will need some more snap bushings drilled.
