Brief Description: D-sub bracket for inputs/outputs
I measured and fabricated a bracket that will fit behind the avionics access panel in and support a 25 pin D-sub that will be used to collect all the various discrete in/out's and any other wires that are not designated for something particular, but may be used as inputs / outputs in the future.
The wires will be put into a D-sub connector and marked that they can be easily tapped into in the future. That was Ralphs great idea....so the bracket is made and I will attach it next session.
