Bob's RV-8 Build Site
Date:  10-28-2021
Number of Hours:  1.10
Brief Description:  AOA / Seat belt bracket
No photos. I attached the right rear seat belt bracket and was looking at the clearance between the seat belt bracket and the AOA micro switch bracket.
Putting in the bolt for the seat belt was a challenge because you have to put a washer for a spacer between the two brackets. Also I couldn't even hope to get the castle nut on far enough for getting the cotter pin in the nut. I searched and found two #4 bolts that were the next size longer....those will work fine. I got the new bolt in the bracket and it appears there will be enough room for everything in that ares.
