Bob's RV-8 Build Site
Date:  10-8-2021
Number of Hours:  2.60
Brief Description:  AOA Microswitch mount and flap sensor mount
I got the AOA micro switch bracket installed and mounted the micro switch. I played around with the adjusements on the switch and got the location locked down. The slots in the bracket attachment point and the micro switch helped to easily adjust the switch.
Moving on I was able to get the arm on the flap sensor and removed the two tab hinge on the sensor bracket and rivet a new three tab hinge bracket on the sensor mount.
AOA Switch
AOA Switch
Switch adjustment
Switch adjustment
Flap Sensor with new connector
